AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
XREF PATH TYPE(Full Path to Relative Path)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
4576 Views, 9 Replies
03-27-2006 11:54 PM
Hi..
Is there any way to change the XREF PATH TYPE (full path type to relative path type) associated with drawings..
< i have been troubled with a huge no: of files received from our client, the problem is i have to change the title block in the paper space which is "NOT FOUND", and the xref path type of all drawings are FULL PATH.. and i cant create a new folder(dont know if this would have worked) to match the xref path in the received files as the drive(M, N, P) on the file doesnot match our drives(x, y,z)..
thank you..
thank you..
Re: XREF PATH TYPE(Full Path to Relative Path)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 03:44 AM in reply to:
aputhukatil
if you want to convert all xrefs in a dwg to relative path try the attached script.
If you want to redifine their path explore "redir" command in express tools.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 03:46 AM in reply to:
aputhukatil
ooops! forgot the file.
soory i don't know the author.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 04:58 AM in reply to:
aputhukatil
Try the "Reference Manager" that is installed together with AutoCAD. You find it under your START button (XP) > All Programs > Autodesk > Your AutoCAD
\Freddy
\Freddy
*neilw
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 08:28 AM in reply to:
aputhukatil
I don't see how you can change the reference type from Full Path to Relative
Path using Reference Manager. Can you explain please?
wrote in message news:5123739@discussion.autodesk.com...
AutoCAD
\Freddy
AutoCAD
\Freddy
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 11:07 AM in reply to:
aputhukatil
To make a relative path AutoCAD have to know the relations between the drawing and external references.
The easiest way for you I think, is to put all the external references in the same folder where the main drawings are located. Then AutoCAD is able to find its external references. With “Reference Manager” you can remove the path and then use the "Project Name Search Path" feature that you find under Files in Options to tell AutoCAD where to look for its external references.
\Freddy
\Freddy
*neilw
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 01:57 PM in reply to:
aputhukatil
If I understand you correctly, you want to specify a path for each project
in the Options/Files/Project Path settings? Would that not be rather
cumbersome to manage Xref's that way? Or are you suggesting he use that
approach just to fix broken paths? In either case, I am not clear how will
change the XREF path setting to relative for any given drawing.
wrote in message news:5124376@discussion.autodesk.com...
find its external references. With "Reference Manager" you can remove the
\Freddy
\Freddy
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-28-2006 02:26 PM in reply to:
aputhukatil
I suggest one of two different ways to solve this problem:
1. Put all your external references together with your main drawings in the same folder. The easy way.
or
2. Make a project in Options>Files>Project Files Search Path and add the necessary folders (where your external references are placed, one or several) under that project. Then you open each drawing, make your project current and then reload your external references. I'm not sure if you have to remove the path from the external references first. If you have to, then "reference Manager" may help you.
\Freddy
or
\Freddy
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-29-2006 06:01 AM in reply to:
aputhukatil
thanks klaudiussen..
i am trying it out..
i m sure this will help me more..
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-21-2012 09:57 AM in reply to:
aputhukatil
In ACAD 2008 I can type in the relative path in the 'Found at' field which shown when you select the xref in 'EXTERNAL REFERENCES' dialog. When you hit enter the path in 'Saved Path' field will change to the relative path you entered and 'Found at' field will change to the full path of the xref if it is found in the relative path.
I found this way after I tried REFERENCE MANAGER which always freeze when I apply changes.
