• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    New Member
    Wrong Area measurement reported.
    80 Views, 3 Replies
    02-03-2006 09:35 AM
    Running AD2006 but feel this is related to just vanilla ACAD2006. Looking at the 2 plines in drawing you would think that the larger outside green pline would be report larger square ft than the smaller blue pline. Clicking area, object, reports 21799 for the green line and 22626 for the blue line. The green area line completely encapsulates and surrounds the smaller blue line? Eh? I already purged it and tried the explode, and pedit to rejoin it.
    Ted
    Please use plain text.
    *R.K. McSwain
    Re: Wrong Area measurement reported.
    02-03-2006 09:57 AM in reply to: Ted K
    Ted K said the following on 2/3/2006 11:35 AM:
    > Hello,
    No error.
    PEDIT your cyan polyline, then go to Edit Vertex, then next.
    Look at the construction of the polyline.
    R.K. McSwain
    http://rkmcswain.blogspot.com
    Ted
    if you look at the properties of the lines, they are not closed.
    If you change them to closed, you will see that the area of the Blue area becomes 21294 sqft.
    When you draw your pline, do not draw the last segment, press "c". This will close the pline. Open plines will cause this type of thing frequently.
    02-03-2006 10:06 AM in reply to: Ted K
    note:
    after you close the pline, you will see that a line will be added from your "final vertex to the initial vertex. (your pline doubles back on itself)
    You will have to correct this be redrawing your pline or exploding and deleting your duplicates, then edit to create a closed pline again.
