AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Why does zoom command deselect objects?
Options
- Highlight
- Email to a Friend
531 Views, 12 Replies
03-11-2010 11:39 AM
When I select an object, then use the zoom command to zoom in, the selected object is deselected. I want to select various objects and use the zoom tool to locate them.
I am quite sure I have been able to select multiple objects and use the zoom tool at the same time. Something seems to have changed. Have I accidentally changed some configuration or option?
Any suggestions would be appreciated.
Don
Don
Re: Why does zoom command deselect objects?
Options
- Highlight
- Email to a Friend
03-11-2010 12:18 PM in reply to:
Donpk123
Always worked like that, out of sight will be deselected, unless you selected them then pan.
and set your pickfirst = 1
Options
- Highlight
- Email to a Friend
03-11-2010 12:36 PM in reply to:
Donpk123
Thanks, Patchy, for the quick reply.
If I understand you correctly, "out of sight will be deseleted" is not quite what I'm doing.
I select an object, then as soon as I enter "Z" and hit return, the object is deselected. The problem is that I want to select a large object and add small object which is in a group of other small objects which I don't want in the selection group. So to add the single small object I have to use the zoom tool to see it clearly. When I choose the zoom tool, I've now lost the large object, although it's still visible, but now deselected. Pickfirst is set to 1.
Don Edited by: Donpk123 on Mar 11, 2010 8:38 PM
Options
- Highlight
- Email to a Friend
03-11-2010 12:42 PM in reply to:
Donpk123
That would be pickadd variable, set it to 1
Options
- Highlight
- Email to a Friend
03-11-2010 12:54 PM in reply to:
Donpk123
Pickadd was set to 1.
Have you been able to do what I describe? That is, select an object and then "Z" + "Enter". Does that object remain selected, or does it deselect?
Don
Don
Options
- Highlight
- Email to a Friend
03-11-2010 12:57 PM in reply to:
Donpk123
I got it now ☺ it got deselected, I use middle button to zoom and pan and didn't run into this problem.
But if you type in command first, then 'z it will work.
Options
- Highlight
- Email to a Friend
03-11-2010 01:11 PM in reply to:
Donpk123
Yes, I often use the mouse wheel to zoom as well, but there are some times when you want to do a large zoom, so the zoom commands are quicker.
I can swear I've been able to use zooming while selecting multiple objects. It's a logical thing to be able to do. What if you're not using a wheel mouse with zoom capability?
Don
Don
Options
- Highlight
- Email to a Friend
03-11-2010 01:24 PM in reply to:
Donpk123
May be it was before realtime and dynamic zoom was introduced, and 'z was the same as z.
*Dean Saadallah
Options
- Highlight
- Email to a Friend
03-12-2010 05:42 AM in reply to:
Donpk123
They do deselect and still do through R2010: use a scroll wheel mouse.
Dean Saadallah
http://LTisACAD.blogspot.com
Dean Saadallah
Options
- Highlight
- Email to a Friend
03-12-2010 06:16 AM in reply to:
Donpk123
Thanks, Dean, for clearing that up. It would have bugged me, thinking I inadvertently changed some configuration.
Don
Don
