• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    *Sabbath
    Transparent hatch
    139 Views, 6 Replies
    07-09-2003 04:21 AM
    I have objects in Autocad 2004 that consists of splines and lines that are
    hatched with a solid fill. I want these hatches transparent. As I see it
    there is two ways to do it, either in Autocad somehow or I export the
    drawing to, for example, CorelDraw and do the fills of colour there. But the
    exporting to Corel does not work. Even when the objects are created as
    regions in Autocad the lines and splines are not joined in Corel and to
    manually join every line in Corel will take months (the lines and splines
    have to be joined to be able to fill the object with a colour). I have tried
    to export as DXF, DWG, WMF, PS and print to file, nothing works.
    So to simplify the question, how do I fill outlines in Autocad and make the
    fills transparent?
    Regards Olof Andersson
    Please use plain text.
    *Kolberg, Matt
    Re: Transparent hatch
    07-09-2003 05:36 AM in reply to: *Sabbath
    I've heard of 3rd party applications that work with AutoCAD for this
    purpose. I believe somwhere in this NG you will find a link, although I'm
    not sure where.
    "Sabbath" wrote in message
    news:E69D2CCFC47322BA2273EF4B0DF46A76@in.WebX.maYIadrTaRb...
    the
    tried
    the
    > fills transparent?
    *Lincoln, Tracy W.
    07-09-2003 05:54 AM in reply to: *Sabbath
    See http://www.motivesys.com/
    Their M-Color application allows for transparent fills.
    Please, DO NOT send technical requests to me via private e-mail
    Tracy W. Lincoln
    Assistant Moderator - Autodesk Discussion Forums
    Discussion Group Links:
    Index: http://discussion.autodesk.com
    Rules: http://discussion.autodesk.com/webx?groundrules
    *Weaver, Mike
    07-09-2003 07:26 AM in reply to: *Sabbath
    If it's in model space, send it to back. If it's in paper space, make sure
    you don't have paper space plotting last (option in the plot dialog).
    HTH,
    Mike Weaver
    the
    tried
    the
    > fills transparent?
    *Weaver, Mike
    Re:
    07-09-2003 09:20 AM in reply to: *Sabbath
    Maybe I should have clarified:
    In model space, send your solid file to back using the draworder command.
    Mike
    "Mike Weaver" wrote in message
    news:53C793659597430AD3AC8D504234ACA7@in.WebX.maYIadrTaRb...
    sure
    > HTH,
    > Mike Weaver
    are
    > the
    splines
    > tried
    > the
    > > fills transparent?
    *Sabbath
    07-09-2003 02:35 PM in reply to: *Sabbath
    fills transparent?
    *Daniel J. Altamura, R.A.
    Re:
    07-11-2003 10:41 PM in reply to: *Sabbath
    Just guessing, but try using an Image or SuperHatch (from Express Tools),
    then make them transparent. They can simply be solid colors. If you use an
    Image, you can clip it with your splines. I haven't tried it, but it just
    might work.
    Altamura Architectural Consulting
    and SoftWorx, Autodesk Authorized Developer
    DAltamura@compuserve.com
    news:33EC8AE8123E7A73A4FA7884DAFB495E@in.WebX.maYIadrTaRb...
    the
    tried
    the
    > fills transparent?
