AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Dave R
Textmask - Can't find wipeout.ar x
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
194 Views, 11 Replies
10-25-2004 07:35 AM
This problem just started ... not sure what triggered it. When I try to use
textmask and use the mask type "wipeout"
it comes back saying 'wipeout.arx not found'. I go into Appload and
wipeout.arx is listed as already loaded. I've tried unloading and reloading
wipeout.arx and it always comes back saying wipeout.arx loaded successfully.
Are there any other settings or files that have to be used?
TIA
Dave
*C Witt
Re: Textmask - Can't find wipeout.ar x
Options
- Highlight
- Email to a Friend
10-25-2004 09:25 AM in reply to:
*Dave R
not sure what to do about your problem, but do have a word (or two) of
advice..
stop using textmask.. 2k5 has a new feature, background mask (far
better than textmask).. you should look into it.
*Rick Keller
Options
- Highlight
- Email to a Friend
10-25-2004 10:22 AM in reply to:
*Dave R
> stop using textmask.. 2k5 has a new feature, background mask (far better
The only problem you run into using the background mask is if you use "lines
merge" the background
masks will not show up.
Rick
*C Witt
Options
- Highlight
- Email to a Friend
10-25-2004 10:26 AM in reply to:
*Dave R
that is true of textmask also, so no loss there.
> Rick
*Rick Keller
Options
- Highlight
- Email to a Friend
10-25-2004 10:30 AM in reply to:
*Dave R
Works ok on my machine.
Rick
"C Witt" wrote in message news:417d3765_3@newsprd01...
>> "lines merge" the background
>> Rick
*Dave R
Options
- Highlight
- Email to a Friend
10-25-2004 10:49 AM in reply to:
*Dave R
What makes background mask so much better than textmask?
"C Witt" wrote in message news:417d290c_3@newsprd01...
> advice..
*C Witt
Options
- Highlight
- Email to a Friend
10-25-2004 11:06 AM in reply to:
*Dave R
first and foremost, background mask is part of the text rather than a
separate entity that you need to keep track of.
second, background mask is also built into your dim style (so if you
turn it on, it will always be there. you won't need to worry about it).
granted background mask can't be used on dtext, but that is easily
solved by not using dtext.
*Dave R
Options
- Highlight
- Email to a Friend
10-25-2004 11:18 AM in reply to:
*Dave R
Seems to work well. Thanks for the tip.
A couple of questions
-Can you set it on all the time or do you have to set it each time you start
mtext
-I can't seem to mask existing dimensions .. is this possible?
"C Witt" wrote in message news:417d40ab_1@newsprd01...
> second, background mask is also built into your dim style (so if you turn
> granted background mask can't be used on dtext, but that is easily solved
> by not using dtext.
Options
- Highlight
- Email to a Friend
10-25-2004 11:29 AM in reply to:
*Dave R
For the dimensions, the masking can be applied within the Dimstyle under the TEXT tab (click on the Fill Color pulldown list and select background) and ALL of your associative dims will automatically update with a background mask.
If you only want to mask a handful of assoc. dims, select the desired dims and start the PROPERTIES manager, and under the TEXT category, click on the Fill Color pulldown list and select background.
*Dave R
Options
- Highlight
- Email to a Friend
10-25-2004 12:10 PM in reply to:
*Dave R
What about just text, not dim. Is there a place to set it on at all times
or do you have to set it each time you start mtext?
"murrayc" wrote in message
news:22110644.1098728996203.JavaMail.jive@jiveforu m1.autodesk.com...
> background mask.
