• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    *C Witt
    Re: Textmask - Can't find wipeout.arx
    10-25-2004 02:21 PM in reply to: *Dave R
    look for a post in the customization NG, called..."mtext background mask default settings" dated 10/11/2004. that should cover your question Dave R wrote: > What about just text, not dim. Is there a place to set it on at all times > or do you have to set it each time you start mtext? > "murrayc" wrote in message > news:22110644.1098728996203.JavaMail.jive@jiveforum1.autodesk.com... > >>For the dimensions, the masking can be applied within the Dimstyle under >>the TEXT tab (click on the Fill Color pulldown list and select background) >>and ALL of your associative dims will automatically update with a >>background mask. >> >>If you only want to mask a handful of assoc. dims, select the desired dims >>and start the PROPERTIES manager, and under the TEXT category, click on >>the Fill Color pulldown list and select background. > > >
    Please use plain text.
    New Member
    11-13-2012 06:06 PM in reply to: *C Witt
    So what if I have imported text from another program and need to apply a background mask? Taxtmask was really good for that.
