AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Solids Mass Properties - Real Weights
Options
- Highlight
- Email to a Friend
222 Views, 25 Replies
04-25-2006 12:25 AM
With the command massprop you can see mass and volume of a 3D solid.
But if you want to have the real weight of this solid, for example in steel, you have to multiplicate the volume with the specific weight of steel (7,86 kg/dm2).
Is there a Lisp Program for AutoCAD 2006 to automate this function?
Or to query different materials, like steel, wood, aluminum, stone,...?
This would be great!
Thanks.
Thanks.
*Laurie Comerford
Re: Solids Mass Properties - Real Weights
Options
- Highlight
- Email to a Friend
04-25-2006 12:45 AM in reply to:
KaJo
Why not write one yourself?
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5153193@discussion.autodesk.com...
kg/dm2).
Thanks.
Laurie Comerford
CADApps
www.cadapps.com.au
kg/dm2).
Thanks.
Options
- Highlight
- Email to a Friend
04-25-2006 01:06 AM in reply to:
KaJo
How can I do this?
I´m not a "lisp-man" ;-)
*Laurie Comerford
Options
- Highlight
- Email to a Friend
04-25-2006 05:36 AM in reply to:
KaJo
I'd do it in VBA.
All you need is a form with:
a listbox of materials;
a button to select an object;
a button to exit when you are finished;
and a case statement based on the material to give a multiplication factor
and a msgbox to report the result each tine you select an object.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5153230@discussion.autodesk.com...
How can I do this?
I'd do it in VBA.
Laurie Comerford
CADApps
www.cadapps.com.au
How can I do this?
Options
- Highlight
- Email to a Friend
04-25-2006 09:56 AM in reply to:
KaJo
Yes, there is, although I haven't tried it yet myself. Had no need until now, so you can be the guinea pig.
Regards
Regards
*ddpcad
Options
- Highlight
- Email to a Friend
04-25-2006 11:56 AM in reply to:
KaJo
dknaggert wrote:
> Hi,
> Regards
that's cool if you happen to understand German
> Hi,
> Regards
Options
- Highlight
- Email to a Friend
04-25-2006 12:48 PM in reply to:
KaJo
I didn't know that. But is the source is there, I'll translate for you. Like I said, I haven't used it before.
Regards
Regards
Options
- Highlight
- Email to a Friend
04-25-2006 01:56 PM in reply to:
KaJo
i was wondering if you could translate a copy for me also. thanks
J.
J.
Options
- Highlight
- Email to a Friend
04-25-2006 02:44 PM in reply to:
KaJo
You can fight over it or each can take a separate copy.Of course, you can customize it by adding more materials or make it more accurate. I did the best I could.
Regards
P.S. I was just going to check it with a 1.0 cu-in block for accuracy and it gave me an error message, yet it worked before on a different body?? I'll keep you posted - although I am probably as good in lisp as you are, I know next to nothing. Message was edited by: dknaggert
Regards
*ddpcad
Options
- Highlight
- Email to a Friend
04-25-2006 02:49 PM in reply to:
KaJo
dknaggert wrote:
> Hi,
> Regards
the source is there. If you could translate that'd be cool!
Dave
> Hi,
> Regards
Dave
