• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    *Bruce Sheldon
    Sheet Set Association
    612 Views, 7 Replies
    03-13-2006 10:25 AM
    Hi all,
    Is there any way to "open" a drawing, "remove association from Sheet Set",
    save, close.
    Simple.
    Am tired of not being able to add drawings to a new Sheet Set. A PITA.
    Bruce
    Please use plain text.
    *Jimmy Bergmark
    Re: Sheet Set Association
    03-13-2006 10:38 AM in reply to: *Bruce Sheldon
    http://jtbworld.blogspot.com/2005/10/remove-sheet-set-association-on-sheet.html
    Best Regards, Jimmy Bergmark
    CAD and Database Developer Manager at www.pharmadule-emtunga.com
    Blog: http://jtbworld.blogspot.com
    JTB FlexReport (FLEXnet / FLEXlm report tool) -
    http://www.jtbworld.com/jtbflexreport
    SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
    or download some freeware at http://www.jtbworld.com
    More on AutoCAD 2006 and 2007
    http://www.jtbworld.com/autocad2006.htm
    http://www.jtbworld.com/autocad2007.htm
    "Bruce Sheldon" wrote in message
    news:5109412@discussion.autodesk.com...
    Hi all,
    save, close.
    Simple.
    Bruce
    *Tim Decker
    03-13-2006 10:40 AM in reply to: *Bruce Sheldon
    Normally if you try to import a drawing into a new sheet set, it will
    give you the option of removing the drawing from a previous sheet set,
    if it was part of a prior set.
    You can also just right click on a drawings existing sheet set entry,
    and it gives you an option to remove it from it's current set.
    SSLOCATE set to 1 will automatically open an associated sheet set if a
    drawing has one, to make it easy to "remove" it, if you don't know
    which sheet set it might be part of.
    Bruce Sheldon wrote:
    > Hi all,
    > Set", save, close.
    > Simple.
    > PITA.
    > Bruce
    *Bruce Sheldon
    03-13-2006 11:15 AM in reply to: *Bruce Sheldon
    Tim,
    Thanks for the reply.
    Doesn't really answer my question, though.
    Let me explain.
    * I want to remove a drawing from any association to a Sheet Set.
    * I don't want to even so much as see the Sheet Set (assume it's on the
    other side of the world).
    * I don't want to see the "script blocker" dialog box that asks if you want
    to remove, etc...
    * I want to script a whole bunch of DWGs, delete any and all Sheet Set
    associations from them.
    "Tim Decker" wrote in
    message news:5109444@discussion.autodesk.com...
    > Hi all,
    > Set", save, close.
    > Simple.
    > PITA.
    > Bruce
    *Tim Decker
    03-13-2006 11:25 AM in reply to: *Bruce Sheldon
    From Jimmy's post above, the blog he points to says that the following
    code, that can be run in a script file (so it can be done to multiple
    drawings) can do the trick. I have not tested this though.
    fileopen "x:\drawings\drawing1.dwg"
    (dictremove (namedobjdict) "AcSheetSetData")
    qsave
    fileopen "x:\drawings\drawing2...
    and so on.
    > Tim,
    > Let me explain.
    > the other side of the world).
    > you want to remove, etc...
    > Set associations from them.
    *Bruce Sheldon
    03-13-2006 12:26 PM in reply to: *Bruce Sheldon
    Tim,
    The LISP command looks like it does the job.
    Anyone know how to stop the dialog box from coming up?
    I'm talking about version 2005 since 2006 automatically removes
    associations.
    I'm running 2005 on one machine and 2006 on another. I can do the script on
    my 2006 machine, but would be nice to know how to stop the dialog on 2005.
    Thanks a lot everyone!
    message news:5109514@discussion.autodesk.com...
    qsave
    and so on.
    > Tim,
    > Let me explain.
    *Jimmy Bergmark
    03-13-2006 12:41 PM in reply to: *Bruce Sheldon
    If you run the script with SmartPurger it automatically stops dialog boxes
    like this one.
    news:5109623@discussion.autodesk.com...
    Tim,
    associations.
    *Bruce Sheldon
    03-14-2006 08:49 AM in reply to: *Bruce Sheldon
    Thanks, Jimmy, I will look into this.
    "Jimmy Bergmark" wrote in message
    news:5109640@discussion.autodesk.com...
    like this one.
    Tim,
    associations.
