AutoCAD 2004/2005/2006 DWG Format
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Polyline corners do not join properly
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1079 Views, 12 Replies
02-09-2007 08:56 AM
How can I get polylines with width to join at the corners without the gap shown in the attached file?
*Jason Rhymes
Re: Polyline corners do not join properly
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 10:01 AM in reply to:
frank.balnius
Use line weights instead of widths.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 10:14 AM in reply to:
frank.balnius
Another couple of suggestions....
Create the straight line as a pline and assign a width.
Create the arc as a "regular" line.
Join them using the fillet command, choosing the striaght line first. This technique will NOT work very well for lines at acute angles.
The second suggestion is downright awkward. Break the lines at the intersection. Stretch the straight line to the left half the specified PL width. (See, I warned you it was awkward!).
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 11:59 AM in reply to:
frank.balnius
I tried your first suggestion and got the same result where the corner of the arc and line do not come to a sharp, crisp corner.
Suggestion two about stretching one line to align with the width of the other would work, but I need the two segments to be one polyline.
So I'm still stuck, but thanks for the effort.
Is this not a problem for anyone else? I didn't think connecting an arc and polyline was such a rare occurrence. Actually, I can't believe it's even a problem.
*Jason Rhymes
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 12:06 PM in reply to:
frank.balnius
>Is this not a problem for anyone else<
Yes it was a problem in r14 and before. That's why when they came out with
line weights in 2000, everyone went to that where end styles can be
controlled in the ctb file.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 12:16 PM in reply to:
frank.balnius
The reason why lineweights won't work in this case is that the polyline needs to have a thickness (not to be confused with width) and will be used in a 3D model. We're trying to avoid using soilds for as many small, thin shapes we would need to have.
*Jason Rhymes
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 12:33 PM in reply to:
frank.balnius
Have you looked into 2007? There's a CONVTOSOLID that coverts a pline with a
width and height to a solid and it still acts like a pline in most cases.
There's also POLYSOLID. Here's a short clip
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-09-2007 01:22 PM in reply to:
frank.balnius
Yes, we're in the process of converting over to 2007right now. I was just asking what I thought was an very basic, easy question that I foolishly thought would return to me a easy solution that I needed to have right away. I guess the bottom line and what I will need to tell all the users in the office, is this type of simple polyline is not possible in 2005.
Very surprising.
Thanks for all the input anyway.
Very surprising.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-22-2010 07:01 PM in reply to:
frank.balnius
Please check that the line type you have drawn your object with is "continuous"
It should be solved.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-09-2010 09:06 AM in reply to:
frank.balnius
If you can draw it with even a *very short* line segment coming around the corner from the other line segment, and have the arc segment be a tangent continuation of that short line segment, it will fill in the corner, because it can do that in line-segment corners, whatever the angle.
Kent Cooper
frank.balnius wrote...
Kent Cooper
Kent Cooper
