• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    Active Contributor
    Plotter confusion/ Windows system printer
    59 Views, 1 Replies
    04-06-2005 06:11 AM
    I am having an issue with a plotter configuration. We have 2 plotters here, with installing 2006 the HP 500 is recognized in layouts created in 2004 and seems to work fine. With the KIP 2000 plotter it is a problem, I get this AutoCAD warning, that I have put in the attachment. I am able to plot to this plotter, but it is not a smooth process, I get the warning everytime i plot to it and I get a plot stamp upsidedown with the plot stamp turned off, something is completely out of whack and I am not sure how to correct this. I have gone through the whole process in add a plotter wizard and am clueless. Do I need to install the driver for this plotter on my computer? All of the plotters are on a server and the only way I know how to find them through add a plotter wizard is to check system printer. Any help would be appreciated.
    Please use plain text.
    *Tracy W. Lincoln
    Re: Plotter confusion/ Windows system printer
    04-07-2005 03:22 PM in reply to: cpd3
    In addition to any replies you might receive or have already received, you may find more information by reading through or searching or additional responses by posting this or any future print/plot related questions in the following discussion group: NNTP discussion group readers use news://discussion.autodesk.com/autodesk.autocad.print-plot HTTP web-based group uses http://discussion.autodesk.com/forum.jspa?forumID=30 -- Tracy W. Lincoln - TLConsulting http://TLConsulting.blogspot.com/ Consulting, Design & Training Specialist Autodesk Discussion Group Facilitator "cpd3" wrote in message news:8867511.1112793092182.JavaMail.jive@jiveforum2.autodesk.com... > I am having an issue with a plotter configuration. We have 2 plotters here, with installing 2006 the HP 500 is recognized in layouts created in 2004 and seems to work fine. With the KIP 2000 plotter it is a problem, I get this AutoCAD warning, that I have put in the attachment. I am able to plot to this plotter, but it is not a smooth process, I get the warning everytime i plot to it and I get a plot stamp upsidedown with the plot stamp turned off, something is completely out of whack and I am not sure how to correct this. I have gone through the whole process in add a plotter wizard and am clueless. Do I need to install the driver for this plotter on my computer? All of the plotters are on a server and the only way I know how to find them through add a plotter wizard is to check system printer. Any help would be appreciated.
