• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    Member
    Thomas1947
    Monitor - Aspect Ratio
    590 Views, 5 Replies
    02-06-2012 02:00 PM
    Will some of you please help me with this problem.
    I just bought a new wide screen monitor for my computer and it has a fixed screen aspect ratio at 16:9 and you can't change it either through the monitor settings or with my Windows XP Home Edition settings. When I draw a square with my AutoCAD 2004, I want to see a square and not a rectangle... see what I mean...?!
    What would be the consensus of opinions among AutoCAD users about modern day computer monitors...?
    There must be a solution to this out there somewhere... please...
    Please use plain text.
    pendean
    Re: Monitor - Aspect Ratio
    02-07-2012 06:13 AM in reply to: Thomas1947
    You are not running the resolution at the screen's default: do that, and your squares will look like squares. From your description, you decided to run it at a "larger" setting to see text or larger icons perhaps and that's the price you pay. unless your video card is choking and is not able to hit the screen's designed resolution of course, then you know that fix is not cheap.
    There is no other way to do it, it's how screens are designed these days: their way, or you put up with the display quirks.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    Thomas1947
    02-07-2012 06:21 AM in reply to: Thomas1947
    My resolution is set at:   1024 x 768
    pendean
    02-07-2012 06:24 AM in reply to: Thomas1947
    That's too low, the AutoCAD minimum too, and not a "wide screen" resolution: unless you bought one heck of a dirt cheap widescreen. It needs to be back up where the monitor is designed to operate: 1920X1080 or 1600x1200 is where most widescreens are these days.
    Member
    Thomas1947
    02-07-2012 07:29 AM in reply to: pendean
    Okay...
    You got me straightened out. Thanx...!
    I learn something every day.
    pendean
    02-08-2012 05:30 AM in reply to: Thomas1947
    Glad it worked: I was just following up for others that may not have understood your response.
