• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    Active Contributor
    Insertion of Blocks
    93 Views, 9 Replies
    12-26-2006 07:31 AM
    Hello
    How can I easily change the insertion point of a block that is already created?
    Thank you so much!
    Please use plain text.
    *None
    Re: Insertion of Blocks
    12-26-2006 09:05 AM in reply to: ds_mother
    ds_mother wrote:
    > Hello
    > Thank you so much!
    Blocks are dwgs. Open the dwg(s) and then type "base" (without the
    quotes). Autocad will tell you the EXISTING base (insertion) point and
    all you have to do is type the new point you want. Then when you
    re-insert the block, you will have a new insertion point and if you have
    any blocks that had been inserted previously, they will all be updated.
    Active Contributor
    12-26-2006 10:10 AM in reply to: ds_mother
    Thank you !!
    *Warren Trost
    12-26-2006 10:40 AM in reply to: ds_mother
    Or move the objects to 0,0.
    "None" wrote in message
    news:5435287@discussion.autodesk.com...
    ds_mother wrote:
    > Hello
    > created?
    > Thank you so much!
    Active Contributor
    12-26-2006 11:57 AM in reply to: ds_mother
    When I created the blocks in 2006, I typed in B to create a block definition. I can't find any drawings. Thanks
    *Warren Trost
    12-26-2006 01:10 PM in reply to: ds_mother
    Also you might look into REFEDIT/REFCLOSE/REFSET.
    wrote in message news:5435394@discussion.autodesk.com...
    Distinguished Contributor
    12-26-2006 02:35 PM in reply to: ds_mother
    Sorry mother, but none don't know none and Warren is learning from him. ;-)
    Actually they are right if you are inserting a "dwg" as a block. That is NOT what you are doing. You created your block right here in the dwg you're in and just want to change the insert point.
    Two ways to do it:
    1) explode the block and redefine it with the desired insert point.
    2) use the Refedit command to gain access to your block and literally move everything to a new location, then refclose and the insert point will stay the same, but all the geometry has moved.
    I prefer number 1 above as it is so much simpler and quicker.
    *Bill DeShawn
    12-26-2006 10:49 PM in reply to: ds_mother
    The old way was to
    1. draw a line from the point that you want to be the insertion point.
    2. EXPLODE the block.
    3. Use the Block command
    4. Type in the name of the block
    5. Click on "Select objects" and type "P" for "previous" selection. Do not
    select the new line.
    (Whenever you explode a block, the objects within become the previous
    selection.)
    6. Click on "Pick Point" and select the first endpoint of the new line.
    7. Click OK to finish the redefinition of the block
    Bill DeShawn
    bdeshawn@nospamsterling.net
    http://my.sterling.net/~bdeshawn
    (website link works now)
    Active Contributor
    12-27-2006 06:07 AM in reply to: ds_mother
    Thanks Madcadd, it worked fine. Mother
    *Jane
    01-01-2007 10:46 PM in reply to: ds_mother
    Hsh BlockManager can insert blocks with different insert points. While
    dragging before insertion, you can change the insert point. HTH
    Jane
    http://vanabc.com/hshsoft/
    http://www.hshsoft.com
    CurveTool
    Hsh Block Manger
    Hsh STL Importer/Exporter
    wrote in message news:5435261@discussion.autodesk.com...
    Hello
    created?
    Thank you so much!
