• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    Active Contributor
    F key toggles and mouse movement
    69 Views, 5 Replies
    12-12-2005 08:49 AM
    I have an odd problem with one of my users - when he toggles an F key item on or off (Ortho, Osnap, etc.) the toggle does not engage until he moves his mouse.
    Let me try and give a more visual picture. He hits the F3 button and, for most of us, if you are looking at your toggle bar at below your command line, you would see the Osnap button engage/disengage. His does not. Until he put his hand on his mouse and moves it in anyway - then, all of a sudden, you will see the toggle button engage/disengage. It's one of the strangest things I've seen, and I haven't been able to find any other remarks on this issue.
    Any suggestions?
    (Specs, WinXP Pro, AutoCAD 2006)
    Thanks -
    Susan
    Please use plain text.
    *Dean Saadallah
    Re: F key toggles and mouse movement
    12-12-2005 09:21 AM in reply to: shallahb
    Is this a stock wired mouse/keyboard combo, or some special
    wireless setup?
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    Active Contributor
    12-12-2005 09:23 AM in reply to: shallahb
    Stock wired mouse/keyboard, and the same ones that I have on 90% of all of my other computers in the office.
    *Dean Saadallah
    12-12-2005 01:39 PM in reply to: shallahb
    Is the mouse cursor off-screen, or hovering over the Windows
    Taskbar?
    Is it just a case of the AutoCAD window not being active? As
    in another application stole Windows 'attention'?
    Dean Saadallah
    Active Contributor
    12-12-2005 01:42 PM in reply to: shallahb
    Nope - I watched over his shoulder while he did it - he was in AutoCAD, the mouse crosshairs were in the middle of the screen, and he was definitely engaged with AutoCAD.
    Valued Contributor
    12-12-2005 01:43 PM in reply to: shallahb
    Mine does it too. It doesn't matter if the cursor is in the middle of the screen or off the edge.
