• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    *James H. Dixon
    Enhanced reference audit problems for database
    94 Views, 1 Replies
    11-16-2004 04:01 PM
    Has anyone had this problem? The following error message comes up when I try to reload an xref: Enhanced reference audit problems for database "path and name of xrefed drawing" (in the form: "Name, Reason, Repair Method"): Override Container [1307C], Broken reference, Remove Override I can't find anything on this error message. What does it mean? And how can I fix it? ________________________________ kodiak_j
    Please use plain text.
    Re: Enhanced reference audit problems for database
    10-03-2012 06:01 AM in reply to: *James H. Dixon
    Hey, old conversation, but I just got this today (in 2011) and can't find much on it.
    Command:
    Command:
    Command: XR XREF
    Command:
    "..............................................................dwg"
    AECC_GENERAL_SEGMENT_LABEL [DBB7], Broken reference, Remove_.regen
    Regenerating layout.
    But it seemed to work for me, the xref is repointed as intended.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
