• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    Active Contributor
    BLOCK NOT REDEFINED WHEN REINSERTED
    71 Views, 6 Replies
    03-13-2006 10:33 AM
    For my paperspace layout I use a standard block with attributes. When I make changes to the original block and reinsert it in the drawing I answer Yes for the redefinition of the block, which AutoCAD seems to do but the original block is not redefined and I have to start over the redefinition of properties of all the attributes, delete the initial block and replace it with the redefined one. Why doesn't AutoCAD redefine the initial block when it is prompted to do so.
    Please use plain text.
    *Dean Saadallah
    Re: BLOCK NOT REDEFINED WHEN REINSERTED
    03-13-2006 11:04 AM in reply to: Arthis
    Attributes are not redefined by that simple act of
    INSERTing, is that what you really mean?
    BATTMAN and ATTSYNC are want you need to correct that.
    Or consider using ATTREDEF or REFEDIT commands to edit your
    block inside the file in the first place without the
    external trip.
    OR simply XREF your block if it is a titleblock, instead of
    inserting it.
    Or you could just rename your old block before reinserting
    the new 'redefined' one if it's an option.
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    Distinguished Contributor
    03-13-2006 11:13 AM in reply to: Arthis
    (Bases are loaded, bottom of the 9th and Dean Saadallah comes to the plate)
    external trip.
    (And there's the pitch and swing and it's a high line drive down center)
    inserting it.
    (It's going...it's going... IT'S GONE!! It's outta the park.)
    (It's a grand slam homerun folks, the 1st of the season for Dean, but I'm sure it won't be the last.)
    Active Contributor
    03-13-2006 11:15 AM in reply to: Arthis
    BATTMAN didn't do the job but ATTSYNC did. Thank you
    03-13-2006 11:18 AM in reply to: Arthis
    (And if you think that was good, next he'll work on your Arthis)
    *Dean Saadallah
    03-13-2006 12:55 PM in reply to: Arthis
    lol
    Dean Saadallah
    *Dean Saadallah
    03-13-2006 12:57 PM in reply to: Arthis
    Cool, I wasn't sure what all you wanted to fix with your
    attributes. Enjoy.
    Dean Saadallah
