• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2004/2005/2006 DWG Format
    Distinguished Contributor
    AutoCAD crashes when hatch selected
    149 Views, 5 Replies
    04-25-2005 12:35 PM
    I want to use AutoCAD 2006 to re-create the boundaries for the hatches in the attached drawing....but it crashes whenever I select the hatch.
    Please use plain text.
    *Rick Moore
    Re: AutoCAD crashes when hatch selected
    04-25-2005 12:54 PM in reply to: CADdaddy.com
    Do you have the properties palette open? If so turn it off and try to select
    the hatch. If that works then go into the properties palette and roll up the
    "Geometry" section so that it doesn't show when picking hatch - you'll have
    to do this on a bit of "good hatch", but the setting will stay across
    drawings
    Rick Moore
    Barnes Gromatzky Kosarek Architects
    www.bgkarchitects.com
    Active Member
    04-26-2005 11:30 AM in reply to: CADdaddy.com
    Looks like you have a proxy object from some other software in this drawing. Do you know which program you imported objects from?
    -Subhash
    *Rick Moore
    04-26-2005 11:50 AM in reply to: CADdaddy.com
    That could be, Subhash, but I was able to keep it from crashing and
    re-create the hatch boundaries by rolling up the geometry section of the
    properties palette
    Rick Moore
    wrote in message news:4826303@discussion.autodesk.com...
    > -Subhash
    04-26-2005 09:36 PM in reply to: CADdaddy.com
    Thanks for the tip. I closed the prop box and no crash.
    Moderator
    06-17-2011 06:29 AM in reply to: CADdaddy.com
    We split your post to it's own topic the AutoCAD Civil 3D forum where there is likely to be more active feedback on the topic.
