• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2004/2005/2006 DWG Format
    New Member
    AUTOCAD 2004 & WINDOW 7
    1763 Views, 6 Replies
    10-25-2009 07:52 PM
    AUTOCAD 2004 DOSE NOT WORK WITH NEW WINDOW 7, ANYONE CAN HELP!!!!!
    Please use plain text.
    *Dean Saadallah
    Re: AUTOCAD 2004 & WINDOW 7
    10-26-2009 05:31 AM in reply to: s_bishara
    Should work with the 32bit version of Win7 just fine, or with it's XP-mode
    option. Otherwise you need to buy a newer version of AutoCAD.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    New Member
    10-28-2009 05:59 PM in reply to: s_bishara
    AutoCAD 2004 will work with windows 7 ULTIMATE with XP Mode 32 bit. Not sure with the 64 bit.
    Member
    01-22-2010 07:53 PM in reply to: s_bishara
    I got Autocad 2004 working with window 7. But I could not get the printer or plotter working. I could print any appilcation but not on Autocad 2004. I went to plot setup and I could not select any printer or plotter. How can we do that?
    Reid
    New Member
    ShelleyJB
    01-09-2012 11:01 PM in reply to: s_bishara
    I am trying to load Autocad 2004 onto my new laptop with windows 7. It wont open after it has installed successfully. can anyone help?
    Distinguished Contributor
    01-11-2012 04:12 AM in reply to: s_bishara
    We area trying out new Windows 7 64 bit computer with our older 2004 files.
    So far everything seems to be working except some plotting issues.
    Our TIFF/JPEG logo came out black, just in 2004, newer versions worked fine.   Staff switched from one to the other & it worked.
    I could have sworn I tried out a pdf plot in 2004 and it worked fine.  Now it isn't.  I was coming here this morning to see it anyone else was having this problem and how to fix it.
    We did have to tell the computer we had a different model of plotter than what we do as Xerox doesn't have a Windows 7 driver for our old plotter.
    New Member
    5660278
    SOLUTIONS ON HOW TO ADD WINDOW 7 PRINTER INTO AUTOCAD2004
    02-07-2012 03:06 AM in reply to: s_bishara
    You can add your win7 OS printer into Autocad2004,I ever try to find solutions before I try this, when I got my solution then I came back to write it down here.
    By the way, please do not hesitate contact me if needed.
    Also, If you want something made in China, please don'T hesitate let me know, it is in my way to do this----advertising
     following step: 1. run Autocad2004  2.click 'file' in autocad and select 'printer manager-----Me myself is Chinese, this is my translation from Chinese Menu into English, maybe not quite exact same words, but you should find near one'  3. double click 'adding printer guide'   4. click 'next'   5. select  'win OS printer' and click 'next'  6. select your printer in win7 OS and click 'next'  7.  click 'next'  8. click 'next', you can change printer name shown on Autocad 2004 in this step.  8. click 'finish'.    Now you can use this printer when you plot  in Autocad2004.
    Regards!
    Wonderson Wang
    Union Fluid Tech.(WeiHai) Co., LTD.
    NO.108,ShenYang RD., ChuangXin Building, WeiHai, ShanDong, China
    Mobile: +86 138 631 59039
    Tel:    +86 631 5660278
    Fax:    +86 631 5660276
    E-mail: Union_tech@126.com
