• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *plothead
    where is my command line?
    101 Views, 3 Replies
    07-02-2001 01:46 AM
    my command line has disappeared, can't make it reappear. thanks
    plothead
    Please use plain text.
    *Baker, Jon
    Re: where is my command line?
    07-02-2001 02:49 AM in reply to: *plothead
    what did you do to make it go bye bye? try to see if it is behind the taskbar. try to hide it or
    make you screen resolution smaller...
    Please scroll and read previous posts, this way you will not post the same exact question, or look
    at the AutoDesk discussion group listings for other groups.
    http://support01.autodesk.com/Discussiongroups.asp
    Jonathan Baker
    R&R Engineers-Surveyors, Inc.
    Denver, Colorado
    "plothead" wrote in message news:f061b02.-1@WebX.maYIadrTaRb...
    | plothead
    *Mick, Bryan
    07-02-2001 03:31 AM in reply to: *plothead
    What does it say in your options dialogue under the display tab -"text lines
    in command line window"? You should be able to set that number to how many
    lines you want down there.
    -Bryan
    Active Member
    07-25-2012 11:33 AM in reply to: *plothead
    Hit "Ctrl+9"
