• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    Active Contributor bmv
    Active Contributor
    resident objects...?
    70 Views, 2 Replies
    02-01-2002 01:53 AM
    I have a number of objects that are on layer X, at least according to the properties dialog box, however if I turn all of the layers except layer X off there are no objects visible. The objects on layer X seem to be connected to layer Y, when I turn just layer Y on the objects on layer X appear.What's up? Is there anyway to fix this?
    v
    Please use plain text.
    *Lincoln, Tracy W.
    Re: resident objects...?
    12-13-2003 05:37 PM in reply to: bmv
    Possibly Blocks defined on Layer Y but inserted in Layer X?
    DO NOT send technical requests to me via private e-mail
    Tracy Lincoln
    Assistant Moderator, Autodesk Discussion Groups
    Discussion Group Links:
    Index: http://discussion.autodesk.com
    Rules: http://discussion.autodesk.com/webx?groundrules
    Product Support: http://support.autodesk.com/
    Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
    Downloads: http://support.autodesk.com/Downloads.asp
    > v
    Member
    Re:
    You must redefine the block, with all entities placed on layer 0, and no other layers existing other than 0.
