• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Medina, Alfredo
    "Extremely small scale factor ignored" (!?)
    2643 Views, 13 Replies
    03-05-2000 10:34 AM
    Has anyone seen this message when trying to scale an object?
    Alfredo Medina
    Please use plain text.
    *Turvill, Paul
    Re: "Extremely small scale factor ignored" (!?)
    03-05-2000 10:46 AM in reply to: *Medina, Alfredo
    Yes. I think it's new to AutoCAD 2000. You can force it to appear by
    using something ridiculously small (such as 1e-99) as a scale factor. I
    haven't experimented to discover just where A2K sets the limit to
    "smallness," but it might be a fun (if useless) thing to do.
    __
    "Alfredo Medina" wrote in message
    news:38C2A8AD.488B7D23@hotmail.com...
    *Medina, Alfredo
    Re:
    03-05-2000 11:01 AM in reply to: *Medina, Alfredo
    Thanks, Paul
    I was using Decimal units, in milimeters. I was drawing a small cone, just
    the wireframe. I had drawn a circle of radius=1 and I had drawn the height
    of the cone as a vertical line of 2.6 units. I just wanted to scale that
    line from 2.6 to 1 and I got this message. I noticed that if I ignore it
    and type R for reference again, the command goes on. But it did not happen
    in other previous releases. Why do some old commands such as Scale start
    doing weird things all of a sudden?
    Alfredo Medina
    > __
    *Turvill, Paul
    Re:
    03-05-2000 12:06 PM in reply to: *Medina, Alfredo
    It's likely Autodesk's way of combatting the problems some have found
    with "precision" that exceeds AutoCAD's limits on significant digits.
    I've found that a scale factor of 0.000000001 (1e-9) works with my
    default settings, while 0.0000000001 (1e-10) fails with the "Extremely
    small scale factor ignored" error.
    Autodesk has all but forsaken its old philosophy about avoiding changes
    that can cause scripts and Lisp routines to fail. Interestingly, R14
    seems not to have such a limit on scaling; no error is ever returned, and
    even though such a small scale factor may make objects too small for even
    the tightest zoom, they are still there.
    __
    news:38C2AF15.8DF0F0B@hotmail.com...
    > Thanks, Paul
    just
    height
    that
    it
    happen
    start
    > Alfredo Medina
    I
    > > __
    *Medina, Alfredo
    Re:
    03-05-2000 01:07 PM in reply to: *Medina, Alfredo
    Paul,
    What is really confusing is that I got that message even before entering any
    scale factor at all.
    I just typed Scale, then I selected the objects, and the error message showed
    up.
    Alfredo Medina
    *Turvill, Paul
    Re:
    03-05-2000 03:38 PM in reply to: *Medina, Alfredo
    That *is* mysterious. Maybe an inadvertant stray click or two got
    interpreted as a "very small distance." In any case, I'll be watching for
    similar behavior (none so far...).
    __
    news:38C2CC8A.3C0C3D29@hotmail.com...
    > Paul,
    entering any
    showed
    > up.
    *Medina, Alfredo
    Re:
    03-05-2000 04:39 PM in reply to: *Medina, Alfredo
    Paul,
    I have some clues. The error message has something to do with Otrack & Osnap,
    while the current view is not the plan view.
    Please take a look at this:
    Start a new drawing. In Ddunits set Type: Decimal. Drawing Units: milimeters.
    Now, draw a square of side = 1
    Now, try to scale it. It works fine.
    But...Switch to an isometric view of the square.
    Attempt to scale it in the isometric view. If Osnap & Otrack are on, the
    "Extremely small scale factor ignored" error message shows up before you
    indicate any scale factor. (?!) If Osnap & Otrack are off, it works o.k.
    Also, even when Osnap & Otrack are on, Scale would work o.k. if you attempt
    to scale the object from a plan view.
    I have seen other weird things related to the new Otrack feature, when
    combined with old commands. It seems that it was not checked with all of
    them, in different situations. None of these things is a big deal, really,
    and the usefulness of Otrack is notorious. I love it because now I can draw
    without using point filters anymore.I think Otrack is one of the coolest
    additions to the program. But, if Autodesk does not put these small problems
    in their "to do list" usually they go on and on forever. The problem is that
    they eventually pile up, and then we have many of those "small" problems here
    and there...
    Thanks for everything, Paul.
    Alfredo Medina
    > __
    > > Paul,
    > entering any
    > showed
    > > up.
    *Hubbard, Danny
    Re:
    03-08-2000 09:45 AM in reply to: *Medina, Alfredo
    Alfredo,
    I tried this a bit and I do get the message about Extremely small scale
    factors, when entering a scale factor with more than 9 decimal place, like
    0.000000009.
    From the sound of what you are running into, is before you enter a scale
    factor, and with your Object Snaps turned on, AutoCAD is trying to scale on
    the fly, so if it snaps to a point that creates to small of a scale factor
    it would return the small scale factor message.
    I would imagine if you turn off you OSNAP's before starting the scale
    command, you would not get the message.
    Also check in Options and User Preferences and the Priority for Coordinate
    Data Entry, the default should be Keyboard entry except scripts.
    Danny Hubbard
    AutoCAD Product Support, US
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    news:38C2FE56.D344023D@hotmail.com...
    > Paul,
    Osnap,
    milimeters.
    attempt
    draw
    problems
    that
    here
    > and there...
    > Alfredo Medina
    for
    > > __
    > > > Paul,
    > > entering any
    > > showed
    > > > up.
    New Member
    Re:
    11-05-2008 10:25 AM in reply to: *Medina, Alfredo
    I have the same problem with some entities in a particular situation.
    If I scale some entities (3 lines), and pick the end point of one of the lines, located very near other entities, as the base point, before I even enter a scale factor I get the message ''Extremely small scale factor ignored'' but I can proceed with the command.
    If I pick another base point, I might not get that message.
    Sorry, wasn't able to send attachment.
    Mon Grain
    joe
    Active Member
    05-10-2012 03:35 AM in reply to: *Medina, Alfredo
    If you save the drawing in 2013 format and re-open the drawing then issue is fixed.
    however this still needs fixing for those working in a mixed environment.
    My findings in summary:
    1. scaling to a base point selected by OSNAP is fine.
    2. scaling to a base point in free space causes the issue.
    3. this behaviour only happens in pre-2013 drawing formats.
    Hope this helps
    Joe
