• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    dynamic link library Msvcp70.dll
    126 Views, 3 Replies
    11-09-2003 10:35 PM
    When starting AutoCAD 2002 (Note: AutoCAD 2004 is already installed and de-installed and re-installed on this machine) the follwing message appears:
    "The dynamic link library msvcp70.dlll could not be found in the specified pat ......."
    Clicking once or twice the message disappears, and I seem not having any problems with AutoCAD.
    Is there anyon (Autodesk) who knows this problem and to solve it?
    Thanks.
    Edward Winter
    Please use plain text.
    *McSwain, R.K.
    Re: dynamic link library Msvcp70.dll
    11-09-2003 11:32 PM in reply to: ewinter
    If you want a response from Autodesk, call your dealer, as they are your primary support outlet. This is a user forum.
    Re:
    11-10-2003 03:57 PM in reply to: ewinter
    R.K. McSwain wrote:
    "If you want a response from Autodesk, call your dealer, as they are your primary support outlet. This is a user forum."
    Okay, put (Autodesk) a side, if this botters you, and I leave the question with "Does anyone know..."
    Regards.
    New Member
    Re:
    12-19-2003 01:59 PM in reply to: ewinter
    There are actually two .dll files that AutoCAD 2002 is missing after AutoCAD 2004 is installed.
    MSVCR70.dll and MSVCP70.dll
    I found the files in my "C:\Program Files\AutoCAD 2004" folder and copied them to my "C:\Program Files\AutoCAD 2002" folder. Problem solved.
