• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Bliss, Charles
    Re: Your Favorite 2000 Features?
    05-18-1999 11:41 PM in reply to: *Grandmaison, Robert
    My favorites:
    1. All the new tracking capability really enhances productivity I especially
      like polar and the new osnaps
    2. Multiple sheet (layouts)
    3. Edged Gouraud shading and Orbit
    4. Solid Editing (still a room for improvement though)
    5. Properties and ADC
    Robert Grandmaison wrote:
    I think there are far more great things in 2000 than
    "peculiar" things
    (read bugs) and I know others feel likewise. Wondering what your
    favorites might be. I'm sure the people who read these newsroups might
    need a satisfying oasis of happiness amongst the angst. Join in the
    fun-
    could be a great way to share new feature abilities with others who
    have
    yet to scratch much beyond the surface. (I'm sure the Autodeskers
    looking in would appreciate some positive feedback on their product
    as
    well!)
    Please use plain text.
    *Jr
    Re:
    05-19-1999 12:47 AM in reply to: *Grandmaison, Robert
    I have not tried yet but I have not read nothing about these improvements.
    Can you tell me some about?
    ____________________________________________________
    Ignacio Arrue
    iam@dossoftware.com
    "Member of the Autodesk Discussion Forum Moderator Program"
    Christal Elliott [Autodesk Support]
    escribió en el mensaje de noticias
    3747c6d3.172954120@adesknews.autodesk.com...
    > I am very pleased with the improvements to Audit and Recovery in
    > correcting problems with drawing files. Makes my job easier :smileyhappy:
    > On Mon, 17 May 1999 11:17:22 -0700, Robert Grandmaison
    > wrote:
    > >I think there are far more great things in 2000 than "peculiar" things
    > >need a satisfying oasis of happiness amongst the angst. Join in the fun-
    > >could be a great way to share new feature abilities with others who have
    > >looking in would appreciate some positive feedback on their product as
    > >well!)
    > Christal Elliott
    > file://Autodesk Support on the Net//
    *Urban, Reini
    05-19-1999 11:05 PM in reply to: *Grandmaison, Robert
    mine are:
    1) Object Tracking
    2) Full VLISP included
    3) QDIM
    4) right clicking the statusline "buttons"
    5) superb API
    6) 3DORBIT
    7) inplace block and xref edit
    8) the overall "mousification": OPM, object tracking, layouts...,
    now i finally can leave my left hand from the keyboard and scratch my
    head all the time :smileyhappy: i dreamed of this for years...
    9) stability. far superior over R14 (e.g. when debugging ARX)
    10) ObjectDBX available via COM methods, and the whole architecture is
    much better now, a fine seperation between UI and DB code.
    Reini
    *Shinn, Dennis
    Re:
    05-20-1999 02:41 AM in reply to: *Grandmaison, Robert
    Greetings
    "Robert S. Carroll" posted the following
    >I especially like MDE. I usually need to work on several drawings in a
    >project at once, and I was constantly opening/closing drawings before.
    >You do have to watch which order you open files however, if you use a
    >lot of xref's as I do, or you will only be able to open them read only.
    Robert-
    Go to the Options dialog under the Tools pull down on the menu bar. Click
    on the Open and Save tab. In the upper right area of this window there's a
    drop down list box for setting the "Deman load" options for xrefs. Select
    Enabled with copy and you'll be able to open any xref at any time
    regardless of the order in which the drawings are opened.
    *Leonard, Bob
    05-20-1999 05:26 AM in reply to: *Grandmaison, Robert
    > favorites might be.
    - Design Center used with MDE. Drag and drop layers, linetypes, fonts into
    other drawings. Nice!
    - Plotting. I was able to install a new printer (HP 8500DN), create
    multiple layouts and begin plotting in minutes, without peeking at the Help
    docs. A very intuitive interface. Multiple layouts are great.
    Bob
    *Carroll, Robert S.
    Re:
    05-20-1999 09:37 AM in reply to: *Grandmaison, Robert
    Thanks Dennis! I'll check it out. It is one of those "new" features I
    have to learn!
    Dennis Shinn wrote:
    > Greetings
    > Robert-
    *Lila
    Re:
    05-24-1999 10:38 AM in reply to: *Grandmaison, Robert
    There have been numerous discussions in the R14 newsgroup on what
    setting is best. A few of us CAD Managers have decided that "disabled"
    is better. It makes AutoCAD work like it did before "demand loading"
    was an option. "enabled with copy" creates unnecessary network traffic
    and makes autocad "copy" the xref to your hard drive. Just that fact
    alone would seems to make opening a drawing with many or large xrefs
    really slow.
    ***Please remove "XXX" from email address when responding directly***
    Click
    there's a
    Select
    *Carroll, Robert S.
    Re:
    05-25-1999 09:43 AM in reply to: *Grandmaison, Robert
    I've been playing with it for a few days since Dennis mentioned it, and
    the biggest problem I have with it is that if I modify an xref in its
    own session, in order to update a drawing with the changes, I have to
    close the drawing and then reopen it, because you cannot simply "reload"
    the xref.
    > really slow.
    > Click
    > there's a
    > Select
    Member
    04-23-2012 09:48 PM in reply to: *Grandmaison, Robert
    Hey Robert,
    What use is DROPGEOM?  the only time it comes up for me is if I have some objects grip selected, and I accidently drag them. (always followed by UNDO - frustrating) The only use for it seems to be as an approximate way to move things (no way to use snaps or specify distances). And since there are very few times when I place things approximately, I would appreciate it if someone would let me know why Autodesk included this seemingly useless command.
