• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Giffen, Hilary
    Unique AutoCad Problem
    47 Views, 1 Replies
    01-03-2003 05:23 AM
    I started using AutoCad 2000 a few months ago and I have been having a
    problem pop up randomly ever since. I will be working along and
    suddenly my screen is showing a screen from sometime in the past. It's
    just as if the past hour or however long never happened. If I UNDO, it
    undoes from that point. And Regen just regens at that point also. It
    is not putting me back to the last autosave, because I autosave every 15
    min and I lost probably an hour's worth of work. It seems to happen
    more often when I zoom, but the last time I was inserting a block when
    it happened.
    The problem has occured half a dozen times and I uninstalled and
    reinstalled AutoCad after it happened the first couple of times. It's
    not happening to anyone else in the office, so it's not a bad AutoCad
    disk.
    Has anyone else ever heard of this problem, and more importantly, do you
    know any way to solve it?
    Please e-mail me presonally if you have any advice.
    hilary@ringdu.com
    Please use plain text.
    *Lincoln, Tracy W.
    Re: Unique AutoCad Problem
    01-03-2003 06:44 AM in reply to: *Giffen, Hilary
    Set ISAVEPERCENT to 1
    Set ISAVEBAK to 1
    Set SAVETIME to 15
    Do not rely on Autosave, learn to QSAVE, and have a good back-up & restore
    procedure.
    As far as the problem causing this I would look into that, which would
    require more detail as to what your PC is, what OS, Memory, etc...
    Please, DO NOT send technical requests to me via private e-mail
    Tracy Lincoln
    Assistant Moderator, Autodesk Discussion Groups
    Discussion Group Links:
    Index: http://discussion.autodesk.com
    Rules: http://discussion.autodesk.com/webx?groundrules
    Product Support: http://support.autodesk.com/
    Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
    Downloads: http://support.autodesk.com/Downloads.asp
