AutoCAD 2000/2000i/2002 DWG Format Archive
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Photoshop to AutoCAD 2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Photoshop to AutoCAD 2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Kevin Nehls
remove -ns- for direct reply
"torbacm"
news:ef4767b.-1@WebX.SaUCah8kaAW...
> I've been trying to import a Photoshop drawing into AutoCAD with no luck.
I have tried to import the drawing as an EPS file but have found that
AutoCAD doesn't recognize the file. I am able to import it as a TIFF or JPG
file but those extensions import the drawing in pixels and not as vector
based images which is what I need. Any suggestions? Does AutoCAD only give
the option of exporting EPS files and not importing? Is there any other way
to import a Photoshop drawing as a vector based drawing?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
box Use OLE Application in the Plotting tab in Options window.
Dean
Saadallah
www.pendean.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"torbacm" <torbacm@obg.com>I've
wrote in message
href="news:ef4767b.-1@WebX.SaUCah8kaAW">news:ef4767b.-1@WebX.SaUCah8kaAW...
been trying to import a Photoshop drawing into AutoCAD with no luck. I have
tried to import the drawing as an EPS file but have found that AutoCAD doesn't
recognize the file. I am able to import it as a TIFF or JPG file but those
extensions import the drawing in pixels and not as vector based images which
is what I need. Any suggestions? Does AutoCAD only give the option of
exporting EPS files and not importing? Is there any other way to import a
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
output is raster data (pixels), not vector data. When you save your PhotoShop
image as EPS, you'll get an EPS with rasterdata. Importing in AutoCAD as Tiff,
Jpeg, Bmp, etc. is the only option (or use a vectorizing program to vectorize
the output from PhotoShop; but this is not a simple task and the results may be
disappointing).
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
torbacm <torbacm@obg.com>I've
schreef in berichtnieuws
href="mailto:ef4767b.-1@WebX.SaUCah8kaAW">ef4767b.-1@WebX.SaUCah8kaAW...
Re:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Photoshop doesn't support vector information of any kind. When opening
an EPS file in Photoshop, you have to specify a resolution to rasterize it
to, and then it tries to make you save it as a PSD as the default option. .
.to save as EPS you have to save a copy, which flattens it, which would
eliminate the possiblity or being able to read any vectors out of
it.
of EPS, but I don't understand how you could possibly get vector
information out of photoshop in the first place.
Dean?
either Illustrator or Streamline, both of which have DXF capability, and both of
which support vector data.
"Dean Saadallah" <
href="mailto:info@pendean.com">info@pendean.com> wrote in message
href="news:098CE87A37775F53244C260516AB2F36@in.WebX.SaUCah8kaAW">news:098CE87A37775F53244C260516A......
Insert your file as an OLE object, and make sure you check
the box Use OLE Application in the Plotting tab in Options window.
Dean Saadallah
href="http://www.pendean.com">www.pendean.com
Re:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Illustrator), so I am not 100% sure about this, but you could try to export
as WMF and import that in AutoCAD. Another option you could try is the
(free) GSView/GhostScript combination. This can read PostScript and convert
to DXF (it's under te Edit menu of GSView, "convert to vector"). BTW, I have
heard that Illustrator 9 supports the AutoCAD fileformat, but if you don't
have 9, that does not help you.
Govert
torbacm
ef4767b.4@WebX.SaUCah8kaAW...
I'm sorry I totally messed up....I meant to ask about Illustrator....I was
using both. So I was asking about converting an EPS file to use in AutoCAD
from Illustrator. I tried to convert to a DXF file in Illustrator but wasn't
given the option. Any more suggestions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What your trying to do is raster to vector conversion, it is not built into AutoCAD software, nor is it in Photoshop or Illustrator. The only programs that will actually change the file is the above mentioned...a converter, it is a separate software. Like Adobe Streamline...and it is not very good, and it only does simple linework. Other stronger programs such as Hitachi Raster Graphics or AutoCAD raster design OCR, it converts graphic files or especially direct scans. although, your precept is an expensive one. Almost nothing comes out perfect, there is a bit of cleaning up afterwards. You also need vast hard drive space to convert large files. The best approach is to import the file in the background "image" command or type "im", attach the file, test the scale...adjust if necessary, and trace over the file in AutoCAD. Newer packages of AutoCAD have this R to V function built into its program. If you are a old school cad user there is such a thing as a digitizer, you can copy large drawings quite accurately, but it is tedious. welcome to the club i've been doing this for 30 years from architecture to civil design there are at least 10 ways to address this issue, but none can beat experience in drawing CAD accurately.
Note: raster is pixtels...little squares, vectors are a geometry formula, AutoCAD is actually a graphics database it uses both, but the drawing is all vector construction using short macros the program manages entities as a database. Enjoy
Ed Banda, EB Architecture and Planning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Umm you realize you're answering a post that's over 11 years old?
