• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Wojtynek, Steve
    Inches to Metric Block Insertion Multiplier
    131 Views, 9 Replies
    10-11-2002 01:12 AM
    Our firm works in the USA and therefore I've set up all our blocks libraries
    and DWT files in inches. I've just added a new set of metric DWT templates
    to the Cad Customization (based on millimeters) for some international
    projects we'll be starting soon.
    Is there a magic variable or dialog box setting in AutoCAD that
    automatically increases the size of an inserted block by 25.4, or will I
    need to create a matching metric blocks library with insertion macros that
    have the multuplier in every line?
    Please use plain text.
    *Reshef, Ella
    Re: Inches to Metric Block Insertion Multiplier
    10-11-2002 01:56 AM in reply to: *Wojtynek, Steve
    if you will organize your 'library' as a dwg containing blocks, then you can
    use the design center to drag the blocks into the dwg.
    one of the miracles of the design center is that the calculation is
    automated !! :smileyhappy:
    but, you will have to make sure that :
    a. dwg units are set (centimeter, inches...light year)
    b. your 'library' dwg as well as the blocks in it are made in the proper
    units.
    Ella
    *Wojtynek, Steve
    Re:
    10-11-2002 02:00 AM in reply to: *Wojtynek, Steve
    Not what I asked... (Design Center is a compared to an
    organized pulldown menu blocks library with slides to view and select from.)
    *Reshef, Ella
    Re:
    10-11-2002 02:10 AM in reply to: *Wojtynek, Steve
    i didn't mean to offend you..
    sorry, it will not happen again
    Ella
    *Alexander, Dave
    Re:
    10-11-2002 04:38 AM in reply to: *Wojtynek, Steve
    At last, someone else not enthused with about design centre.
    Dave Alexander
    *Saadallah, Dean
    12-13-2003 05:36 PM in reply to: *Wojtynek, Steve
    No magic fix: you will have to deliberately plan for it in each case.
    Dean Saadallah
    http://www.pendean.com
    Expanded Links Page
    http://www.pendean.com/lt/links.htm
    "Steve Wojtynek" wrote in message
    news:73819CC84CDE547157BA8A715B83A65B@in.WebX.maYIadrTaRb...
    libraries
    templates
    *Wojtynek, Steve
    Re:
    Wasn't offended. I'm just tired that most of the new fangled AutoCAD
    features actually slow you down. Recent drops in AutoCAD sales apparently
    justify my position.
    "Dean Saadallah" wrote in message
    news:smileyvery-happy:A6B47D0E705AB063A303EBD364F5D10@in.WebX.maYIadrTaRb...
    > Dean Saadallah
    > Expanded Links Page
    > libraries
    > templates
    that
    *Alexander, Dave
    Re:
    What we do is have two types of blocks, one is a graphic block, (note
    symbol) that is scaled by the plote scale and dimensioned equipment blocks
    that are inserted at a scale of 1. But we also have one set of metric blocks
    and one set of imperial blocks. They are the same except the base unit is
    25mm for metric and 1 inch for imperial. The block names are the same except
    that the imperial blocks begin with " I " and the metric blocks begin with "
    M ". We use a startup lisp that reads the dimscale setting of a drawing and
    if it is a metric scale, 1:50, 1:100, etc , it sets a mpfx lisp variable to
    " M " and if the dimscale is imperial , 1"= 48'0" ( 1:48) then the mpfx is "
    I ". A little menu lisp strcats the M or I to the block name with the path
    and Bob's your uncle.
    Dave Alexander
    *Sandy Workman
    01-07-2004 09:59 AM in reply to: *Wojtynek, Steve
    Does anyone else deal with 'hard' 'soft' and 'true' Metric issues? "Saadallah, Dean" wrote in message news:27541548.1071808335799.JavaMail.jive@jiveforum2.autodesk.com... > No magic fix: you will have to deliberately plan for it in each case. > > -- > Dean Saadallah > http://www.pendean.com > Expanded Links Page > http://www.pendean.com/lt/links.htm > -- > > "Steve Wojtynek" wrote in message > news:73819CC84CDE547157BA8A715B83A65B@in.WebX.maYIadrTaRb... > > Our firm works in the USA and therefore I've set up all our blocks > libraries > > and DWT files in inches. I've just added a new set of metric DWT > templates > > to the Cad Customization (based on millimeters) for some international > > projects we'll be starting soon. > > > > Is there a magic variable or dialog box setting in AutoCAD that > > automatically increases the size of an inserted block by 25.4, or will I > > need to create a matching metric blocks library with insertion macros that > > have the multuplier in every line? > > > > > > >
    *Sandy Workman
    01-07-2004 10:24 AM in reply to: *Wojtynek, Steve
    Does anyone have clear definitions for 'soft' 'hard' 'true' metric . . . and which you use on Metric required projects? "Saadallah, Dean" wrote in message news:27541548.1071808335799.JavaMail.jive@jiveforum2.autodesk.com... > No magic fix: you will have to deliberately plan for it in each case. > > -- > Dean Saadallah > http://www.pendean.com > Expanded Links Page > http://www.pendean.com/lt/links.htm > -- > > "Steve Wojtynek" wrote in message > news:73819CC84CDE547157BA8A715B83A65B@in.WebX.maYIadrTaRb... > > Our firm works in the USA and therefore I've set up all our blocks > libraries > > and DWT files in inches. I've just added a new set of metric DWT > templates > > to the Cad Customization (based on millimeters) for some international > > projects we'll be starting soon. > > > > Is there a magic variable or dialog box setting in AutoCAD that > > automatically increases the size of an inserted block by 25.4, or will I > > need to create a matching metric blocks library with insertion macros that > > have the multuplier in every line? > > > > > > >
