• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Rutledge, Phillip
    Filename without the path
    44 Views, 2 Replies
    04-18-2002 12:21 AM
    Hi there,
    If you select "File" on the menu bar, there will be a list of the last
    drawings opened. This list doesn't show the drawing "path". However, if
    select "Window" on the menu bar, it lists all the files current opened and
    their path.
    Is there any way of eliminating the drawing path so the list only shows the
    Filename?
    Thanks in advance for your help.
    Phillip
    Please use plain text.
    *Wengerd, Owen
    Re: Filename without the path
    04-18-2002 03:37 AM in reply to: *Rutledge, Phillip
    Phillip:
    > the Filename?
    Tools->Options->Open & Save and uncheck 'Display full path in title'. :smileyhappy:
    Owen Wengerd
    President, ManuSoft ==> http://www.manusoft.com
    VP Americas, CADLock, Inc. ==> http://www.cadlock.com
    *Rutledge, Phillip
    Re:
    04-18-2002 04:47 AM in reply to: *Rutledge, Phillip
    There it is plain as the nose on my face. Thank you Owen.
    Phillip
    "Owen Wengerd" wrote in message
    news:99326FAF9C0F1BBBF14572CD723F3976@in.WebX.maYIadrTaRb...
    > Phillip:
    > > the Filename?
    > Owen Wengerd
