• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *sundog
    Exit stubborn dialog
    76 Views, 4 Replies
    12-13-2003 05:18 PM
    How do I exit out of a poorly written dialog box that will not go away.
    It's an add on off some freebie website that I've been using because of the
    neat way it rearranges the menus. Now I'm paying.
    Only thing that seems to work is cntrl>alt>delete. Anything I can do in
    AutoCAD. Secret endcommand command. cntrl>alt>space>jklland9>dotheshimmy?
    Matt Fridell
    saladays@gwtc.net
    Please use plain text.
    *D, Paul
    Re: Exit stubborn dialog
    12-13-2003 05:18 PM in reply to: *sundog
    we can't tell you the secret endcommand. If we did, we would have to kill
    you...
    sundog wrote in message
    news:0423680FABB827D1595688CF655B2264@in.WebX.maYIadrTaRb...
    the
    > Thanks,
    > Matt Fridell
    > saladays@gwtc.net
    *Lincoln, Tracy W.
    What does ESCAPE or CTRL-C do?
    Can you TAB within the dialog box to get to the CANCEL?
    DO NOT send technical requests to me via private e-mail
    Tracy Lincoln
    Assistant Moderator, Autodesk Discussion Groups
    Discussion Group Links:
    Index: http://discussion.autodesk.com
    Rules: http://discussion.autodesk.com/webx?groundrules
    Product Support: http://support.autodesk.com/
    Knowledgebase:
    http://support.autodesk.com/ViewAnswerworks.asp
    Downloads: http://support.autodesk.com/Downloads.asp
    <0423680FABB827D1595688CF655B2264@in.WebX.maYIadrTaRb>...
    not go away.
    >Thanks,
    >Matt Fridell
    >saladays@gwtc.net
    *sundog
    Re:
    ESCAPE, TAB or CTRL>C don't do anything but blink the dialog. I think that
    the only choice in the dialog references the dialog so that you are in an
    endless loop. I would tweek the nose of the guy who did this, but I'm sure
    that he had his reasons..
    When I end the app through ctrl>alt>delete it says that it is waiting for
    input from me? So, I give it imput of several varieties and body
    contortions and go on my way.
    The main frustration is that I don't normally go for the key combination
    that brings it up, but only hit it accidently. The file the command is in
    is locked up in a .fas too. Can you decode those things?
    Thanks guys,
    Matt Fridell
    saladays@gwtc.net
    "Tracy W. Lincoln" wrote in message
    news:smileyvery-happy:A48A90C5B00EEF1CD804D0A434FCA86@in.WebX.maYIadrTaRb...
    *Lincoln, Tracy W.
    Re:
    You might first try whomever created the application, then
    you might want to ask over in Customization (not a
    programmer) and post what it is, ARX, LISP, VLISP, EXE,
    VBA...
    Tracy Lincoln
    Knowledgebase:
    <9F6876C8E5760FB9F0184BA8CC23968F@in.WebX.maYIadrTaRb>...
    you are in an
    this, but I'm sure
    is waiting for
    and body
    key combination
    the command is in
    >Thanks guys,
    >Matt Fridell
    >saladays@gwtc.net
    in message
