• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    *Pro
    Dimension text Spacing With Metric Units
    93 Views, 4 Replies
    11-26-2003 11:29 PM
    When dimensioning in Metric (ie. millimetres), I use the Decimal units for my dimensions.
    I am wondering if there is a way to either put a space or a comma after the thousands postion of the dimension text
    For example, if I dimension an object that is 12.0m long, the text in millimetres comes out as 12000. I want it to either look like 12,000 OR 12 000
    Anyone have any suggestions?
    Please use plain text.
    Distinguished Contributor
    Re: Dimension text Spacing With Metric Units
    11-27-2003 09:03 AM in reply to: murray-clack
    Since you want a different format than what's being offered to you by the software, you can either 1) edit each dimension as you do it 2)Write your own dimensioning command. I don't think there's a dimension variable setting that will give you what you want...I guess you know this already. Maybe someone else can deliver the miracle you need.
    *Pro
    Re:
    11-29-2003 05:14 AM in reply to: murray-clack
    Actually, a miracle worker DID come to my rescue with a simple technique as outlined below.
    While modifying a dimstyle in the DDIM command, click on the PRIMARY UNITS tab, enter the following values:
    Unit Format = Decimal
    Precision = 0.000
    Decial Separator = either "comma" or "space"
    Round Off = 0.000
    Measurement Scale Factor = 0.001
    Zero Suppression = Leading: checked & Trailing: unchecked
    Re:
    11-29-2003 09:39 AM in reply to: murray-clack
    Is it really a miracle? Have you tried it and
    look at the results? You must be dreaming...
    you just change the decimal point to another
    type comma or space and nothing else....
    Better luck next time....Haste makes waste!
    *Pro
    Re:
    11-30-2003 12:19 AM in reply to: murray-clack
    First of all, the results worked for me. And second, I don't remember you providing anything useful except sarcasism. Therefore, who's wasting time now?
