• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    Valued Contributor
    DELETE KEY WON'T WORK ANYMORE?
    2323 Views, 4 Replies
    11-13-2002 05:39 AM
    My delete key won't work anymore? Also, if i select a bunch of items on the screen and then enter a command it won't work. It worked before. Any help is appreciated.
    Please use plain text.
    Distinguished Contributor
    Re: DELETE KEY WON'T WORK ANYMORE?
    11-13-2002 05:49 AM in reply to: Elwrong
    Set Pickfirst to 1?
    11-13-2002 05:35 PM in reply to: Elwrong
    If you are more menu driven then go to tools options selection and tick noun/verb selection.
    James
    Active Member
    09-15-2006 03:47 PM in reply to: Elwrong
    ahhh...learn something new every day. I just spent an hour trying to figure out why my stupid delete key stopped working in the middle of a drawing!! Thanks!
    New Member
    08-24-2012 12:57 PM in reply to: Elwrong
    Go figure. Same sitch: in the middle of working on a drawing the ability to delete was terminated. Tools/options/selection/(check)noun/verb selection -  did the trick. Thank you. I never would have come to that conclusion on my own.
