• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2000/2000i/2002 DWG Format Archive
    Distinguished Contributor
    Re: Command In Progress
    03-14-2011 03:16 PM in reply to: mfretwell
    Another 2 cents--
    I have just encountered this problem, with AutoCAD 2011. I couldn't save a drawing, plot it, or use plot preview from the quick access menu bar. I attributed the problem to 3D commands--mesh editing, etc.--but had no real reason to do so. Although I couldn't save or plot, I could execute other commands. Following an earlier reply, I entered Save at the command line, successfully saved the drawing under another name, opened that drawing, which I could then plot.
    Please use plain text.
    Active Contributor
    Re: File will not save even after creating a new dwg - please HELP!!!
    04-12-2012 02:41 PM in reply to: mfretwell
    Got the same message "...nit save because...not in soecified format...", but i'm jst data referencing surfaces!...has anybody solved ths problem?
    New Member
    06-25-2012 12:10 PM in reply to: vewright
    Hi Guys
    Here we were facing the same problem and one of the guys that work here and he came with the following solution:
    When starts the AutoCad open a file and on the comand line type "filedia" and then type the value "1". That totally solved our problems.
    att,
    Alex
    09-07-2012 07:06 AM in reply to: alexmoretto
    any solution yet?
    in 2013 here... and I can't enter any commands
    2013 Civil 3D
    New Member
    02-03-2013 01:28 AM in reply to: ktm125
    In this case I use a command "saveall" and after that close the drawing and open it again.
