• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2000/2000i/2002 DWG Format Archive
    Member
    Autocad 2002 (property box shows no selection when i select a line)
    331 Views, 7 Replies
    12-11-2008 11:35 AM
    Autocad 2002
    I am having problems with the properties box. When i select a line the properties box shows "no selection" therefore i cant get any of the properties of the item selected. I am not exactly sure what I did but I bet it is a pretty simple fix. Please help! Thank you.
    I have attached a screen shot so that you can see what i am talking about. Edited by: grind77 on Dec 11, 2008 7:36 PM
    Please use plain text.
    *Jason Rhymes
    Re: Autocad 2002 (property box shows no selection when i select a line)
    12-11-2008 12:48 PM in reply to: grind77
    Check your PICKFIRST and PICKADD variables. Should be set to 1.
    Jason Rhymes
    3D Solid Power Toys
    including Multi Solid
    Stretch
    href="http://www.acadianagraphics.com">http://www.acadianagraphics.com
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Autocad
    2002 I am having problems with the properties box. When i select a line the
    pretty simple fix. Please help! Thank you. I have attached a screen shot so
    7:36 PM
    Member
    12-12-2008 05:58 AM in reply to: grind77
    Both the PICKFIRST and the PICKADD variables were set to 1.
    Member
    12-12-2008 06:01 AM in reply to: grind77
    Thank you Jason. But unfortunately that was not it. Both the PICKFIRST and the PICKADD variables were set to 1. Can you think of anything else?
    *Dean Saadallah
    12-12-2008 06:31 AM in reply to: grind77
    You ran a Windows Registry Cleaner on your PC and it wiped out Properties
    command. A reinstall of AutoCAD is the only fix (don't forget to fully patch
    it afterwards, and stop using a Windows Registry Cleaner that does not have
    the ability to stay away from AutoCAD entries).
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Member
    12-15-2008 01:48 PM in reply to: grind77
    Thanks all for your help!
    *tex shalter
    12-18-2008 01:04 PM in reply to: grind77
    before reinstalling Acad try this reg cleaner.
    It's old, free, and from Microsoft. I've used it many times on many
    computers always great results.
    http://majorgeeks.com/download458.html
    good luck
    wrote in message news:6090405@discussion.autodesk.com...
    New Member
    04-10-2012 01:37 AM in reply to: grind77
    I m Facing same problem please tell me the solution.
