AutoCAD 2000/2000i/2002 Archive (Read Only)
where is my command line?
3 REPLIES 3
546 Views, 3 Replies
my command line has disappeared, can't make it reappear. thanks
plothead
3 REPLIES 3
what did you do to make it go bye bye? try to see if it is behind the taskbar. try to hide it or
make you screen resolution smaller...
Please scroll and read previous posts, this way you will not post the same exact question, or look
at the AutoDesk discussion group listings for other groups.
http://support01.autodesk.com/Discussiongroups.asp
Jonathan Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
"plothead" wrote in message news:f061b02.-1@WebX.maYIadrTaRb...
| plothead
What does it say in your options dialogue under the display tab -"text lines
in command line window"? You should be able to set that number to how many
lines you want down there.
-Bryan
SgtElPavo
Hit "Ctrl+9"
