AutoCAD 2000/2000i/2002 Archive (Read Only)
startup template
5 REPLIES 5
esmondwyt
197 Views, 5 Replies
startup template
The same question maybe asked thousand times by others before. Can anybody tell me how can I changes the default template to others which I want. Everytime I startup acad2002, It display a blank template. If I press 'new' command, it will show me the template I prefer. But for conveinance, I prefer everytime I double click the acad2002 icon & autocad start with the my prefer template rather than blank template. Thanks for anybody's help.
5 REPLIES 5
in reply to: esmondwyt
Start with specific drawing template
http://usa.autodesk.com/getdoc/id=TS17888
Add startup switch (you want /t)
http://usa.autodesk.com/getdoc/id=TS66634
Startup switches
http://usa.autodesk.com/getdoc/id=TS22957
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
What about options/"file" tab/"drawing template file location" Seems simple
but why doesn't this work?
"Tracy W. Lincoln" wrote in message
news:024263DF38723D8854A8B92BA47B366B@in.WebX.maYIadrTaRb...
> Startup switches
> Tracy W. Lincoln
That (changing the path) just points AutoCAD to a folder (location for the
templates) where using the /t switch in a start-up switch allows you to
specify which "specific" template (.DWT) to start AutoCAD up with. The /t
switch will use whatever DWT file is specified as long as it exists and is
in that pathed folder.
Tracy W. Lincoln
Works well. Thanks Tracy
news:573C1DA9FDFC828455C40D8A6C1BA467@in.WebX.maYIadrTaRb...
> Tracy W. Lincoln
Glad it helped.
Tracy W. Lincoln
