AutoCAD 2000/2000i/2002 Archive (Read Only)
problems with viewport
4 REPLIES 4
198 Views, 4 Replies
I am having a problem with viewports within multiple layouts. The problem
is when I go into the model space of the viewport, Autocad zooms extent of
the entire model. Autocad normally would allow you to enter the model
space, then wait for the next command. I would then be aloud to pan, draw,
edit or anything else.
Any suggestions would be great
Mike Otte
E&A Consulting Group, Inc.
4 REPLIES 4
Lock the viewport, double click to get in it, set UCSFOLLOW to 0 (zero).
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Mike Otte" wrote in message
news:23092BE358B338EDBA163D6A5C0355FC@in.WebX.maYIadrTaRb...
draw,
> Thanks
> Mike Otte
Set UCSFOLLOW to 0 within each of the the viewports.
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Thanks Dean and Tracy, that did the trick. Now, what is UCSFOLLOW? and Why
would you want to us it?
Mike Otte
Help > Index > UCSFOLLOW look at the various offerings.
Tracy Lincoln
