AutoCAD 2000/2000i/2002 Archive (Read Only)
pathing disappears when change profile
5 REPLIES 5
251 Views, 5 Replies
Here's a strange problem that only occurs on certain computers. If I set some network paths in Files\Support File Search Path for the Tools|Options configuration setup, they get lost if I switch to a different profile and then back again. I've tried exporting the profile, I still lose my network files. Everything else stays the same.
Anyone have any ideas why this is happening? Options other than network file paths stick around.
Phil Boudreau
pcboudreau@mactec.com
5 REPLIES 5
You need to save those settings like this:
1) Make your changes
2) Export Profile
3) Import that profile
Otherwise those settings you exported are just in the .arg file and not
saved in the registry when you change profiles.
HTH
Kevin Nehls
"pboudreau" wrote in message
news:f1662e4.-1@WebX.maYIadrTaRb...
> Hi,
> Phil Boudreau
...or make your changes, exit AutoCAD, then restart AutoCAD.
> 2) Export Profile
One thing I forgot to mention. All the computers in question are running Windows 2K, with AutoCAD 2000 from a network install using the license manager.
Tried that. Instead of the different network paths showing up, I get a top level path that is the name of the profile??
Something like this:
Before
c:\program files\acad2000\LISP
N:\projects\shared folder
After
testprofile
Hm, If I remove the profile option from the startup shortcut (/p profilename), then it keeps the same file associations from session to session. Now we'll only have to change the pathing information if someone who doesn't have access to those network files opens CAD.
Oh well, that's the reason we went to profiles in the first place.
