> When plotting and reopening files the insertion points for systems
> furniture are now over sized. Does anyone know how to change the
> settings to resize these insertion points? If I explode the blocks,
> to remove the insertion points, then I loose the attributes.
> Attachment decoded: untitled-1.htm
As far as I know insertion points don't show up unless you have actually
placed a point entity there. If that is the case then go to "Format->Point
Style..." and choose whatever option you want. The first one is nothing if
that's what you want.
matthew g.
