Kelly,
Try this...
- Turn on and thaw all layers
- Zoom Extents, Zoom .8x
- Begin the Erase command and at the select objects prompt, type ALL
- While still in the select objects prompt, press R to remove
- Pick everything on screen with a crossing window
- Press return to erase what you can't see, then purge again.
This process doesn't require any additional software, if it works for your
conditions.
Hope that helps,
Tim Ulrich
HOK Houston CAD Manager
"Kelly Taylor" wrote in message
news:84D3404844B8E5205A8BDA26B7B3F8EB@in.WebX.maYIadrTaRb...
> Has anyone had this problem--blocks appear in your drawing, but you can't
> find them anywhere--I can even erase everythingin my entire drawing and it
> still leaves 10-12 blocks that "cannot be purged." No xrefs are attached.
> Is there anyway to clean this up--where should I look for these blocks?
> thanks. . .kelly
