AutoCAD 2000/2000i/2002 Archive (Read Only)
What is Fuzz Distance??
6 REPLIES 6
mrwwilliams2
31118 Views, 6 Replies
Within the multiple option of the pedit command it asks for the Fuzz Distance. Normally I just enter and skip it, but I am curious to know what it means, or what it is used for.
Thanks Matt
6 REPLIES 6
in reply to: mrwwilliams2
Matt,
Hitting F1 (Help) and using the Ask Me tab.... putting in Fuzz Distance
PEDIT's Joined Polyline Segments
You can join a line, an arc, or another polyline to an open polyline if
their ends connect or are close to each other. If the ends are not
coincident but are within a distance that you can set, called the fuzz
distance, the ends are joined by either trimming them, extending them,
or connecting them with a new segment.
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
For example, you want to join lines
into PLINES, but the endpoints don't
match. FUZZ DISTANCE is a distance
you can input to say join any lines
whose endpoints are this (FUZZ) far
apart.
too bad they dont have a fuzz factor for hatching areas by picking points,
eh?
Steve-O
Politically Incorrect
I'm more familiar with the term "fudge factor", as in the expression: "If
you don't have the dimensions, just fudge them".
"Steve-O" wrote in message
news:8A5538BA6DDCA9F380164F9C33E7C632@in.WebX.maYIadrTaRb...
> eh?
> Steve-O
>"...the ends are joined by either trimming them, extending them,
or
connecting them with a new segment."<
TAKE NOTE...
An overlapping plane will not always
trim, it may add a line segment.
I don't know if this is just an error
with my setup but it has frustrated me with a few drawings...
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #0000ff 2px solid; MARGIN-RIGHT: 0px">
mrwwilliams2
the Fuzz
to know
for.
Matt,
You can
their ends
coincident but are
new
segment.
Please,
e-mail
Tracy
Lincoln
Discussion
Group Links:
Index:
href="http://discussion.autodesk.com">http://discussion.autodesk.com
Rules:
href="http://discussion.autodesk.com/webx?groundrules">http://discussion.autodesk.com/webx?ground...
Product
Support:
href="http://support.autodesk.com/">http://support.autodesk.com/
Knowledge
Base:
href="http://support.autodesk.com/ViewAnswerworks.asp">http://support.autodesk.com/ViewAnswerwork...
Downloads:
href="http://support.autodesk.com/Downloads.asp">http://support.autodesk.com/Downloads.asp
zaakirk
hi guys i tried using the fuzz distance of lets say 2 polylines 10mm apart and entered the fuzz distance of 10mm and it still hasnt joined the lines. can anyone help me with this? it would be a useful tool
