Derek -
Unfortunately the HTTP web side of the newsgroups is not allowing
carriage returns to show properly. Messages there show as one
long line that just keeps wrapping. This is a known problem and
scheduled for repair.
If you are able to use the NNTP newsgroup reader side of the
newsgroups, carriage returns show properly.
A user posted this tip on properly spaced lines/paragraphs from
the HTTP side:
Place your text or code between a pair of PRE /PRE html tags:
Line 1
Line 2
Line 3
or
If you're faced with one of those posts and want to get a clearer
picture, a quick solution is to view the HTML source. If you're
using another browser the commands might be slightly different,
but for Internet Explorer right-click somewhere on the message in
question and from the popup menu select View Source. Notepad will
open up with the HTML source in it. Press F3 and search for
something unique in the post. You will then see the message as
the originator posted it in plain text.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
dellboy wrote:
> Hi,
> I know that this forum is prehaps not the one to be using, but
> I can't find one for just general querys. Any way the qeustion
> is? How do I format my message so that say all line in an
> autolisp routine are on separate line?
