Show only
Search instead for
In addition, make sure that the "Demand load ObjectARX apps" is not disabled
in the Options->Open and Save dialog.
Jeff
"OLD-CADaver" wrote in message
news:32643161.1080334541970.JavaMail.jive@jiveforum1...
> Try reloading ACMTED.ARX from the support directory.
On Fri, 26 Mar 2004 20:50:21 GMT, mmwick
wrote:
>Unknown command "MTEXT". Press F1 for help. MTEXTED is set to internal. Any help?..please.
Check to see that DEMANDLOAD is set to 3.
Good, now we know tha it wasn't being DEMANDLOADed. Follow Mrs White and Mishler's advice and set DEMANLOAD=3. Then make sure the support directory is in the search path.
You might try "REDEFINE" "MTEXT"
if someone has set "UNDEFINE" "MTEXT" they have told ACAD that "MTEXT" is not a command (an old prank)
You can "UNDEFINE" any command
