AutoCAD 2000/2000i/2002 Archive (Read Only)
Undo auto zoom extents
4 REPLIES 4
august
1625 Views, 4 Replies
Just recently AutoCAD 2002 has started to automatically zoom extents while switching from a paper space layout back to model space. In model space I was zoomed in on a particular section and of course would like to return to that same view! There must be a switch to return this to normal. Does anyone have any suggestions?
Thanks, John
4 REPLIES 4
old-cadaver
in reply to: august
UCSFOLLOW?
in reply to: august
Lock your viewports as a habit, if you have never done it, start. Inside each viewport, UCSFOLLOW needs to be set to zero to skip the Zoom to extents you describe. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
srtlilly
in reply to: august
This did not work for me. It wont let me select a viewport and the ucsfollow did not work.
pendean
in reply to: srtlilly
You have to turn on and thaw the layer the viewport is drawn on first before you can select it to lock it.
Try again.
