LDD does not permit Multiple Documents in the same session.......as the
command line is telling you. It has always been this way. You CAN have
Multiple doc's in Land Enabled Map, if that is what you want.
Jeff
check out www.cadvault.com
"cadpro78" wrote in message
news:30402128.1099681365015.JavaMail.jive@jiveforum1.autodesk.com...
>I have been having this problem with my SDI variable lately that permits me
>from opening more than one drawing in AutoCAD Land Desktop. Whenever I
>perform exactly what the 'Help' command recommends, I always get that was
>an invalid action response from the command prompt.
> Here is the command line to my problem:
> Command: sdi
> Enter new value for SDI <3>: 0
> The current setting for SDI is required by a loaded application.
> Cannot set SDI to that value.
> *Invalid*
> Command: sdi
> Enter new value for SDI <3>: 1
> *Invalid*
> Command: sdi
> Enter new value for SDI <3>: 2
> Requires 0 or 1 only.
> Enter new value for SDI <3>: sdi
> Enter new value for SDI <3>: 3
> (((IT WILL NOT LET ME ENTER ANYTHING BESIDES A 1 or A 2.)))
> Can anyone help my dilemma??
> Cadpro78
