On Wed, 31 Oct 2001 21:38:16 -0800, wrote:
>AutoCAD R14 had a command (Previously in bonus tools) called `BURST' which
>allowed you to explode attributes containing text into regular text but
>keeping the value of the attribute as the text.
>Where has this gone?? Is A2K2 an upgrade or a downgrade??
>Does anyone have a routine which will achieve this result??
I believe it is an Express Tool, so if you did not take advantage of
the free download when it was available you will have to see if you
can use your R14 version. As long as it is a LSP file you should be
able to use it in 2000.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
