AutoCAD 2000/2000i/2002 Archive (Read Only)
Paper Space/Clipping Plane problem
20 REPLIES 20
Message 1 of 21
brite750
898 Views, 20 Replies
When I try to use clipping plane cammand there are two problems. One problem is that when your use the slice part of clipping plane, often what your slicing through does'nt show up, i.e. steel column shows up as little dots were edges of column would be, in other words, if you took a slice through an I-beam it only shows as 12 little dots in the pattern of the I-beam. The other problem is when you pick the clipping plane command you don't get the whole picture of your model, i.e. doing framing plans of a building, you may only get a few levels of your building showing in the clipping plane window, so how do you get the rest of the floors to show? I'm kinda new to this PS thing at least as far as using it for steel drawings, what am I missing?
20 REPLIES 20
Message 21 of 21
in reply to: brite750
On 06.12.2003 15:39 OLD-CADaver wrote:
> I hadn't tried the one from your site, it seems to do exactly what I
> wanted, even on very small viewports.
we'll see if that can be proved in practice 😉
> Thanks a load, your time and help are appreciated.
you're welcome, glad I could help.
besides, that also got me another example/useful tool for my 3d training
classes 😉
ruul
