Show only
Search instead for
We have a border from a new client that is in Paperspace. The view port limit is a polyline. I would normally grip the view port to pull up the properties and lock the display this way. When I grip the view port I don't see the misc. column in the properties box. Does any one know why this is. Or is there a type-in command that will lock my display so an inadvertent zoom in model space will not mess up the scale? Thanks in advance, Daniel
Assuming PICKFIRST is set to 1
You can also select the viewport and right-click > Display Locked > Yes
or
You can also change the Display locked setting in the Properties dialog
box.
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
