AutoCAD 2000/2000i/2002 Archive (Read Only)
PDF file name with Model (1) added
2 REPLIES 2
KARIM
675 Views, 2 Replies
Hello
When I create a PDF file from AutoCAD 2002 using Acrobat distiller I get "Model (1)" at the end of each PDF filename.
Is there a way (other than manual renaming) to remove "Model (1)" and just get the same file name as the DWG file?
Thank you
2 REPLIES 2
in reply to: KARIM
No, it's a feature of AutoCAD writing to file you don't have access to.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
in reply to: KARIM
Not sure if this will help, but a by product of having a file name like
DRAWING.1.DWG (in our case the dot 1 is a the revision level of the
drawing) will remove that -Model or the -Layout name from the PDF file
created... (at least it does with AutoCAD 2002 and Adobe Acrobat 5.? We
typically only have 1 layout per drawing (at least in my discipline) as
per our standards.
I am sure someone in the Customization discussion group could utilize
the -PLOT command and DWGNAME to come up with either a script or lisp
routine... while they are at it can you have them create a PP routine
(for plot previous)?
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
