The file was saved as R2000, probably not exported.
Unfortunately, I do not have access to the creator. Nor am I certain what the file was created on.
I am some what confident it was created using Acad Electrical, but I am not sure what revision.
It is a wire harness drawing that has numerous, non-editable tables. The tables can not be moved, copied, pasted, rotated, made into block ect....
If they are exploded, the text goes to a different font, making the data unusable.
I also tried to convert to R2000 using TrueView 2010. This had no effect, probably because I do not have the original file. It is already in R2000 format.
1. is there any way to decifer what the original software is? If I can do that, I may be able to work with it.
2. Is there a way to install the correct object enabler for the missing application 'object DBX classes' it is looking for and substituting proxy graphics?
Is was also looking for AcDbDimAssoc, but I was able to install the object enabler from the utilities & downloads area and this error went away.
I am looking for a way to work with the existing data, rather recreating all.
-Will
