Most likely a shared file was deleted when you uninstalled R14. You need
to reinstall and the file will be restored.
Kevin Ulm
CAD Coordinator
International Knife & Saw, Inc
kevin.ulm@iksinc.com
Tel: (859)283-6610
Fax: (859) 283-6672
-----Original Message-----
Posted At: Friday, November 23, 2001 10:50 AM
Posted To: 2002general
Conversation: Mtext stacker not working
Subject: Mtext stacker not working
Has anyone run into this problem?
I was working with ACLT 2000i with ACAD R14 installed on the same drive
but not used.
I installed ADT3 and uninstalled R14.
Since then, I cannot edit stacked text in LT2000i or ADT3, getting a
message similar to this:
Autodesk MTEXT stacked text server not installed, Stacked text no longer
editable.
While I could reinstall to see if it solves the problem, I wanted to
know why it happened. Any ideas?
