AutoCAD 2000/2000i/2002 Archive (Read Only)
Maximize Drawing Area on Startup
8 REPLIES 8
Message 1 of 9
353 Views, 8 Replies
I want AutoCAD to start with my drawing area maximized. How do I do this?
8 REPLIES 8
Message 2 of 9
make a file named acaddoc.lsp and place it in C:\Program Files\AutoCAD
2002\Support or whatever your path is.
Inside acaddoc.lsp you can put the code
(command "_.zoom" "_e")
This will run on every drawing you open.
Best regards: Jimmy B
CAD manager at www.pharmadule-emtunga.com
Take a look at SmartPurger or download some freeware at
http://jtbworld.vze.com
"Gary Hanna" wrote in message
news:f099c83.-1@WebX.maYIadrTaRb...
Message 3 of 9
okay, so you can see the windoze title bar for the actual drawing...
i think this is shown like that because sometime ago you may have cascaded
multiple drawings in AutoCAD. if you open AutoCAD via shortcut, maximize
drawing1 and close. then reopen a drawing and see if that works..
A2Ki, SurvCad CES, Win98 se
Remove NO SPAM from my email address to email
Jonathan J. Baker
R&R Engineers-Surveyors, Inc.
Denver, Colorado
_________________________
Message 4 of 9
Just beware of saving when you are in an unlocked viewport, or you'll mess
up your view the next time you open your drawing.
David R. Wilde
"Jimmy B" wrote in message
news:B5B4FAF922CA433F5CA2F8131597E44C@in.WebX.maYIadrTaRb...
this?
Message 5 of 9
this only zooms the drawing entities to extents.. not making the window of
the drawing file full sized..
Jonathan J. Baker
Denver, Colorado
this?
Message 6 of 9
but then again as a re-read your question...
are these for new drawings or existing drawings??
for new drawings, you should set this up in a template. zoom as big as you
want, or use zoom and limits then save as the default template.
for existing drawings, you could do what Jimmy says...
Jonathan J. Baker
Denver, Colorado
"Jon Baker" wrote in message
news:6BA3E5D3183A81C13B156BB034788BAE@in.WebX.maYIadrTaRb...
> Jonathan J. Baker
> Denver, Colorado
this?
Message 7 of 9
If you add the following code before zooming you avoid that problem:
(if (= (getvar "TILEMODE") 0) (command "_.PSPACE"))
Take a look at the trialversion of SmartPurger or download some freeware at
"David Wilde" wrote in message
news:7792B65D35BA5E6DC3EBD4FF680214A0@in.WebX.maYIadrTaRb...
> David R. Wilde
> this?
Message 8 of 9
Right-click the icon on your desptop, select properties, click the
shortcut tab, in the "Run:" pulldown select maximized, click "apply",
then click "ok". This will maximize acad on startup, if the drawing is
not maximized (2000 and up), double-click the drawing border, close acad
and restart. As long as you don't exit acad in a tiled mode, your all set.
-Josh
Message 9 of 9
On Wed, 21 Nov 2001 08:21:44 -0800, "Gary Hanna"
I take it you do not want to pick the Maximize button on the drawing
titlebar.
This being the case, you should only have to do this once. AutoCAD
should remember this between sessions until there is a crash when it
goes back to a window.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
