Hi all,
I'm making some fixtures to fit parts that I have in MasterCAM files (version 10 if it matters). MasterCAM allows you to save as a .dwg or .dfx, however AutoCAD 2002 gives me the following error when trying to open them:
Unknown value "AC1021" encountered in drawing version.
Invalid or incomplete DXF input -- drawing discarded.
My understanding is that the file is for 2007/08/09 versions of AutoCAD.
I've tried one suggestion of opening it in MS Word and converting, saving as a .txt, converting, then renaming the file extension back to .dxf to no avail. Any other suggestions short of upgrading to a 2007 or newer version of AutoCAD?
Thanks!
Solved by Patchy. Go to Solution.
